New Here...Need Help fixing up my car.
Old Mar 12, 2007 | 05:11 PM
CK9's Avatar
CK9
Default New Here...Need Help fixing up my car.
Hey, I just need some good advice on what to do with my new Mirage. I just bought it and dont know a lot about it. I've been reading a lot about it and I like it already. Please help me out putting those extra HP on it. I love how the Evo 5 Bodykit looks so I'm buying that and having my car painted soon. So any ideas on what to do to the engine? Is a '97 1.5L.
Old Mar 15, 2007 | 02:29 AM
Josh's Avatar
Default RE: New Here...Need Help fixing up my car.
if u want horsepower than the mirage won't fit u unless do an evo swap. Swap ur 1.5 with a better mitsu engine. It would go along wit the body kit any ways,don't make ur car look fast if u don't plan on makin it fast. put exhaust on that thing to, make it sound like a beast. My friend did that with his mirage and it worked out good, i'd of dun it but then my mirage was hit and i went and bought a honda, i've hadmy civicjust over a month and already made it faster, i'm gonna do an H22 swap on it, but stillI can't wait till i come back to mitsu, i miss how good the cars look. **** i flat out miss my mirage.
Old Mar 15, 2007 | 03:45 AM
Lil Evo's Avatar
i think we need to maks some sort of sticky out on this, because this has been discussed several times. Mirage and fast generally aren't used in the same sentance together, although there are exceptions. Here's the little speech (again).
First, you need a vision for the car. Don't just start throwing on mods aimlessly without some sort of goal in mind. Is this going to be your daily driver, or the weekend track car? How much time can you put into it every week, how long can you afford to have it in pieces on your garage floor without missing school/work (or both)? What's your end goal, do you want all show, all go, or a little bit of both? Do you want to play it safe and keep it all naturally aspirated, or go the forced induction route, or go big with a swap? What's your budget like, when and how are you going to afford the parts and labor you'll need (dyno tuning isn't cheap). This is what separates the import enthusiast from the ricer. The enthusiast has a carefully laid out plan with everything thought through and an ultimate goal in mind, the ricer sees something shiny and zip ties it on.
After you've answered these questions, the the fun stuff begins. I would suggest, no matter where you want to go in regards to your car, you start with the suspension. What good is a performance minded car if it can't turn? The mirage already handles soundly, but a set of lowering springs, performance struts, braces and sway bars will make it handle as if it were on rails.
Next, begin with the basic modifications that you'll need. A cat back exhaust system is in order (no bigger than 2.25" unless you plan on adding spray or a turbo), as well as a performance intake. This is where most people stop, either because they don't have the time, money, motivation, or some combination of these, to continue with the car. If, however, you continue on the NA route, here's what I'd do.
Start with a bigger throttle body, either one from a 4g93 (1.8L Mirage engine) or a turbo Eclipse TB. However, this will be usless without freeing up the air inside the intake manifold. Get one that has been ported, a set of 275cc injectors, adjustable FPR, adjustable cam gear, RPW 4-1 header, test pipe, plugs, wires, and a few various odds and ends, and something to tune it with (Greddy Emanage or the Apexi SAFC both work exceptionally well), and you've got a killer all engine 4g15. Don't expect to be trouncing V8's, but you'll be able to hang with a few of the big boys of the import world.
Turbo is a whole other nightmare, so unless you've got cash to spend and a lot of tylonol for the headaches, stick with NA until you've got the knowledge base and experience to tackle a turbo project.
Old Mar 19, 2007 | 11:43 AM
CK9's Avatar
CK9
ORIGINAL: Lil Evo
Very well explained. I do want to make it faster. My college is basically all paid and I work 38 hours weekly and I used to have a CRX but it got wrecked. I'll just go with the mods first and when that's done, I'll go with the exterior. I do have time on my hands to put out this project. I'm going to make some research on everything you've said. So far everything looks real balanced. I'll update every once in a while. Thank you again.
Old Mar 19, 2007 | 01:30 PM
Lil Evo's Avatar
one more lil tid bit, check out www.mirageforums.net if you havn't already, there's a huge knowledge base there and people who can build these engines with their eyes closed. good luck on the car, and definetly keep us updated.
fungusboy
Dec 15, 2012 03:27 PM
rickfrick
Oct 7, 2012 01:11 PM
crzydrumer14
Oct 29, 2007 07:04 PM
3000gtman
Oct 22, 2007 01:08 PM
maorifulla
Nov 24, 2005 02:29 PM
