Fixing up my brakes - little help? trying to chose parts
Old Dec 10, 2012 | 02:42 PM
fungusboy's Avatar
Default Fixing up my brakes - little help? trying to chose parts
Ok, so i need to fix up my braking system. Its been a while, and figure I'd do it myself this time. It would be very Gusta if you guys could help me make sure i didn't forget anything, as well as help me decide on good parts.
its a 2003 Outlander, FWD, front brakes are rotors and rear are drums.
OK, so heres what i already got coming in the mail for the front of the car.
PowerStop Complete Brake Kit, Power Stop Brake Rotors and Pads, Powerstop Brake Kit
I think this set covers Both Rotors and both sets of brakes? Can you guys confirm this? They seem to fit the bill. I have it set on the site for my car, so compatibility shouldn't be an issue.
I dont think i need anything else for the front right? please let me know if i am. Dont wana find out the hard way
>_>
<_<
._.
Moving to the back. Since they be drum brakes (which im not too familiar with) I'm really going to need your guys opinion on this.
which of these should i be looking to get for the drum?
03 2003 Mitsubishi Outlander Brake Drum - Brake - Beck Arnley, Centric, Pronto, Winhere, Rear - PartsGeek
I was thinking the one from Centric - getting 2 of them obviously. But should i be looking to get a different one?
as for the shoe set, I was thinking the 2nd one in this list (ones from Beck Arnley)
03 2003 Mitsubishi Outlander Brake Shoe Set - Brake - Beck Arnley, Bendix, Centric, Genuine, Wagner, Rear - PartsGeek
It looks like they come with 2 sets, which is all i need. But once again, should i bee looking for a different set?
I was told there is a set of springs involved with drum brakes that i should be looking to replace as well just for good measure. I have no idea what they would be called, or where to get them. A link to some place where they are affordable would be awesome. i cant imagine them being expensive in the first place.
So besides the spring for the drums, am i missing anything? Is my selection good?
Thanks for the help guys!
Old Dec 11, 2012 | 01:06 AM
Burtonrider10022's Avatar
Are you looking to "upgrade" the brakes or just quality OEM replacement? If it's the latter then I'd say your selections look good. Make sure you check a lot of places for prices, auto parts prices vary hugely from site to site.
If you wanted an upgraded brake kit, I'd say the front set is still a good choice (unless you wanna break the bank). But for low cost improvements you can get stainless steel braided brake lines pretty reasonably and those tend to make a big difference. Also, you could always check part numbers or just compare them, and see if the disk brakes from the newer Outlanders could be retrofitted to your rears. Just a thought.
Make sure you check and lube your emergency brake while you got it all apart, btw.
Old Dec 11, 2012 | 08:56 AM
nesser's Avatar
The star adjusters are usually cleaned up, greased and reused on drums. You may want to replace them if you're replacing all the springs/c-clips/hardware too. Depends how they look, better to buy them before the job and return them to a local auto store if you don't use the new ones. That's the problem with online shopping you can't have consumables on hand just-in-case.
Find a good how-to for a general brake drum installation online which will explain how to find your grease points on the back of the shoes and the basic workings of all the springs. Get a spring tool to save your knuckles and take lots of pictures so you can look how things were installed. Do one side at a time so you can look at how the other is installed.
Old Dec 11, 2012 | 05:21 PM
fungusboy's Avatar
Thanks guys.
They're just to replace the originals. Not really an upgrade.
Old Dec 15, 2012 | 01:12 AM
fungusboy's Avatar
OK, so just to make sure, i need -
*2 drums
*2 drum shoe sets
*and this drum kit hardware kit
03 2003 Mitsubishi Outlander Drum Brake Hardware Kit - Brake - Centric, Rear - PartsGeek
anything else?
Old Dec 15, 2012 | 02:36 AM
fungusboy's Avatar
also, made a video of the replacements. Its looking nice, but perhaps might need some adjustments.
http://www.youtube.com/watch?v=aVgmb...ature=youtu.be
Old Dec 15, 2012 | 03:27 PM
fungusboy's Avatar
Here are some before and afters for the heck of it
msport_2_outlander
Jan 9, 2015 07:30 AM
rickfrick
Oct 7, 2012 01:11 PM
3000gtman
Oct 22, 2007 01:08 PM
CK9
Mar 19, 2007 01:30 PM
maorifulla
Nov 24, 2005 02:29 PM
