Mitsubishi
Go Back   Mitsubishi Forum - Mitsubishi Enthusiast Forums > Mitsubishi Models > Mitsubishi Lancer and Lancer Sportback
Old 05-10-2007, 03:42 AM
chis51hd chis51hd is offline
Default Defective idle control servo... Improvise!
Hello everyone. I own a 1994 Lancer GLi (4G15 engine) with 87,000km. on it. After purchasing the car I noticed that the engine wouldn't idle up when the airconditioning was turned on. I took it to my usual mechanic, but they couldn't find the problem. So we went to another mechanic who specializes in fuel injected/electronically controlled engines. He immediately found that the idle control servo was defective. He also said that he already encountered others with the similar problem (apparently this is inherent in older Lancer models), and upon replacement of the servo, the problem usually comes back. So we came up with a "solution". We just left the servo as is, and replaced it with a mechanical system. First they installed an actuator--pretty common device, and attached the terminals to the aircon compressor, so it would activate when the aircon is turned on. Then tapped an air hose (not sure which one) to supply airflow to the actuator. Then attached a sort of vacuum hook to the throttle body. When the actuator is activated by the aircon, it also activates the vacuum hook and pulls the idle "thingy" (the one where the accelerator cable is attached to), and brings the rpm up to 1,000. Problem solved.
I just would like to know if anyone else has tried this, and if there would be any ill-effects to this procedure? The car runs fine, and engine idle is sufficient when the airconditioning is turned on. I can see that it's a pretty simple fix, and I only spent about $20 (parts and labor).
Hope to hear your opinions on this. Pictures below:
[IMG]local://upfiles/12443/7165C31FBF7B4034A955686741082842.jpg[/IMG]
[IMG]local://upfiles/12443/B679E51BC8224963B2A9317A7DD22528.jpg[/IMG]
Old 10-31-2009, 03:19 AM
WestGold WestGold is offline
Thanks for this very useful information. Keep it up.
Tags
4g15, control, gli, idle, imglocalupfiles124437165c31fbf7b4034a9556867410828 42jpgimg, lancer, localupfiles124437165c31fbf7b4034a955686741082842j pg, mitsubishi, problem, servo, throttle
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
