Engine swop - Galant 2.0 V6 6A12
Old Jul 17, 2007 | 03:18 PM
lemmyb's Avatar
Default Engine swop - Galant 2.0 V6 6A12
Hie,
I have just found this forum, and it is very informative. I have just taken delivery of Galant with the 2litre V6 6A12 engine. The engine is blown and am considering fitting the 2.5 V6 motor. Is this possible? Do i also need to change the gearbox and computer box? (My vehicle has an automatic gearbox)
Your help will be greatly appreciated
Regards
lemmyb
Old Aug 5, 2007 | 12:33 AM
slc0817's Avatar
Default RE: Engine swop - Galant 2.0 V6 6A12
I don't believe that there are any 2.0L V6 engines made for the galant or any other car for that matter. My galant had a 2.4L Inline 4 Cylinderengine in it.
What year is your galant?
Shaun
Old Aug 5, 2007 | 12:35 AM
slc0817's Avatar
Oh and is it a DOHC or SOHC?
If you have a VR-4, you are very very lucky.
Sweet, you have the DOHC 2.0 L V6. So jealous. You wouldn't want to put my stupid 2.4L SOHC I4 4G64 engine in that, that would be so embarrassing.
You might be able to find an engine on www.car-part.com
Good luck on finding an engine.
Old Aug 19, 2007 | 10:11 AM
RedGalant2k1's Avatar
the 6a12 is a Euro/JDM only engine. It never made it to the states. What he is asking is if the VR4 2.5L 6a12tt fits, and it should with the addition of new electronics and new transmission, though the AWD would be a costly swap.
Old Oct 1, 2007 | 11:05 PM
2.0_V6's Avatar
My Galant also has the 6A12 engine.Yup, you can swap in the 6A13 engine into the E54 chasis withno major problems.If you're guying half cut, usuallthe wiring and ecu are all included. pretty straight forward. Good Luck!
Old Oct 30, 2007 | 12:01 AM
njjfudge's Avatar
The 6a13 is rotated 180 degrees for the 6a12. In other words they are not facing the same direction. The swap can be done but it will not be an easy drop in. You will have to custom fab motor mounts.
Old Oct 31, 2007 | 08:41 PM
jpmontero98's Avatar
i wanna see pics of this ride...sounds cool
Old Nov 28, 2007 | 05:51 PM
2.0_V6's Avatar
Hi,my Galantalsocome with the 6A12 engine, but not the twin turbo version though..
Old Jun 7, 2010 | 01:57 AM
ridndrty's Avatar
Default hay guys
i all so have a 6a12tt 2.0l v6, but my car is missing rear half of the loom can u's help and tell me if a computer is ment to be under the passenger seat? and if eny 1 has a diagram on what wire from that point goes were to the back of car.
thanks
ash_kimura
Feb 6, 2007 11:12 PM
Schwitzer Turbo
Nov 14, 2006 04:43 PM
FUS3ON
Oct 15, 2006 07:35 AM
streetlegal2006
Nov 13, 2005 01:42 AM
sonoftheking
Mar 5, 2005 06:56 AM
