Need help on Oxygen sensor
Old Oct 29, 2007 | 05:37 PM
teddyzhu's Avatar
Default Need help on Oxygen sensor
my car is 2001 Diamante LS, 6 cylinder. Failed on SMOG check, it's the O2 sensor, ( Bank 1 Sensor 2 ), can someone help me locate that part that i can buy it online, the quote from dealer is $240.00 which is too much.The error code is "PO141 O2 sensor heater fault(bank 1 sensor 2)" and "PO 401 EGR " .[:@]
Old Oct 29, 2007 | 07:46 PM
Default RE: Need help on Oxygen sensor
I am not sure which is bank one on mitsubishi's but, bnk1 sen2 the downstream sensor is at fault there. P0401 is egr insufficient flow so check to see if the egr valve is clogged.
Old Oct 30, 2007 | 07:50 AM
Id say first check the vacuum lines to the EGR and the EGR itself. And the o2 sensor is on the exhaust after the Cat
Old Oct 30, 2007 | 03:09 PM
Which side is bank 1 and bank 2 on mitsubishi engines?
Old Nov 7, 2007 | 12:07 PM
Oyoriae86coupe's Avatar
give me the part number ill try to get it cheaper, where are you located?
mrbo
Jan 4, 2015 09:52 AM
mrbo
Nov 28, 2014 01:07 PM
puwit321
Sep 30, 2014 12:10 PM
skoot61
Jan 26, 2009 08:13 PM
teddyzhu
Oct 29, 2007 07:52 PM
