MY 2002 ECLIPSE PROBLEM
Old Jan 22, 2008 | 06:20 PM
swaelok's Avatar
Default MY 2002 ECLIPSE PROBLEM
My wife blew a football size hole in the side of her engine block of her2002 eclipse gs. the good news is i found an identical engine with only 20k miles on it. i swapped out the engine and it fired up on the first try, and the car runs like brand new again. so whats the problem right...... well the car will not go into gear. it is an automatic transmition, and yes i bolted the flywheel to the tourqe converter. the transmition still is full of transmition fluid, and when the engine blew the car glided to a stop, there was no tire lock up or anything. if anyone has an idea please let me know. thank you
Old Jan 23, 2008 | 10:23 AM
shreff99's Avatar
Default RE: MY 2002 ECLIPSE PROBLEM
Try next to the gear shifter itself...should be a tiny "lid" that you pop open. Get in that and move the "switch??" Can't remember what this is called..Damn brain fart!
Old Jan 23, 2008 | 12:16 PM
ORIGINAL: shreff99
To bypass the shift interlock switch
I know this sounds dumb, but is the linkage hooked up?
Old Jan 26, 2008 | 07:11 AM
swaelok's Avatar
OK. I tried that and yes the linkage is hooked up. the problem isn't the shifter i can move the shifter into drive, reverse, and neutral, but the car goes nowhere. when i shift into these gears the engine idols up like it is ready to take the load of the gear from the trans. should shift into but nothing happens.
bookmonster
Oct 15, 2012 09:31 PM
jeh0824
Jun 9, 2010 07:45 AM
sparky
Aug 3, 2005 11:55 PM
jsparkman
Jul 24, 2005 05:25 PM
ruslancer
Mar 5, 2005 02:59 PM
