Exterior Talk about your rims, body kits, and other exterior mods here.
Rim Size
Old Dec 17, 2004 | 01:31 AM
DrAgOnBoY45479's Avatar
Default Rim Size
Whats the biggest rim you can get on a 2g Eclipse without modifying anything?
[IMG]local://upfiles/2507/CBEC00BE8071460BBF9D165E06927CC6.jpg[/IMG]
Old Dec 17, 2004 | 06:11 AM
Spyderman9803's Avatar
Default RE: Rim Size
19's will fit but they will rub....biggest with no wheel rub is a 18" rim 7.5"wide........225/40/R18 are the size tires to use....thats my setup and I have no problems
Old Dec 17, 2004 | 03:21 PM
SpyderGS's Avatar
19's can fit with a spacer, or if you get the correct offset, but they'll stick out from the fender wells quite a bit, and mess up you steering. I think 20's will hit the side molding. To tell you the truth though, some wide 17's are gonna be good enough if you're going for road racing or anything like that.
Old Dec 19, 2004 | 04:51 AM
midnght's Avatar
ORIGINAL: SpyderGS
.... To tell you the truth though, some wide 17's are gonna be good enough if you're going for road racing or anything like that.
Correct. I run 235/45/17's with BFGoodrich KDW (old tread) with a 17x8 wheel. NO rubbing, no fender rolling. Offset is +42
Old Dec 19, 2004 | 03:20 PM
Playboy4ll23's Avatar
Yeah i would go with 18's
Old Dec 19, 2004 | 05:59 PM
Thanks... that helps alot because i cant seem to find anything about it online... havent really searched very hard but o well... thanks
Old Dec 19, 2004 | 11:16 PM
midnght's Avatar
Look on this webpage, it will give some insight.....
http://www.vfaq.com/mods/macross/2Gfitment.html
Zfred10
Mar 12, 2008 09:23 PM
bobofly
Mar 19, 2007 06:15 PM
TwiztidMamii
Oct 31, 2006 03:38 AM
Silvertooth
Oct 18, 2005 10:09 AM
LAIDMITS
Jun 20, 2005 02:16 AM
