93' SR Oil Leak 203,000 mi.+
Old Dec 27, 2004 | 02:39 PM
Mitsibitchi's Avatar
Default 93' SR Oil Leak 203,000 mi.+
I have an oil leak coming from the main seal in front and from the valve cover according to the dealer. They want to replace the timing belt/water pump/tensioner/belts and do a tune up as well. How hard is it for a do it yourself on the issue of repairing the main oil seal and valve cover gasket? ANYONE????
The Mitsubishi is a 1993 Montero SR 3.0L engine
Old Dec 29, 2004 | 07:51 PM
mikewired's Avatar
Default RE: 93' SR Oil Leak 203,000 mi.+
Your lucky to only have this start at 203,000. Mine did it at 135,000. Got a local shop to do all of this for $600.00. Changed both cam seals as well, all were leaking.
Old Jan 31, 2005 | 02:47 PM
Winshawn's Avatar
It is probably not the valve cover, it is probable the cam seals at the back of the engine. All of those jobs are time consuming. To change the timing belt you have to take out the radiator and a bunch of other junk. The cam seals have very limited acces between the head and the firewall. I had the dealer replace those on my engine. I dont have a mechanic that I trust and felt the dealer would stand behind any future problems.
Yury
Feb 20, 2011 03:03 PM
ccernst
Jan 14, 2011 08:38 AM
TheRock0720
Nov 12, 2010 12:30 PM
darkman0127
Jul 9, 2004 06:32 PM
OZ2003
Nov 26, 2003 10:38 PM
