throttle body q's
Old Jan 19, 2005 | 09:01 PM
1398spdr's Avatar
Default throttle body q's
Im lookin at getting a bigger TB for my spyder, my question is are there other parts i will need, such as a 1g elbow for a 1g TB, will upgrading the fuel system in this case help? thanks..........
Old Jan 21, 2005 | 10:07 AM
customizedrides's Avatar
Default RE: throttle body q's
I would imagine that you'd have to get some additional parts for that, but not possotive n witch ones. I would consider upgrading the fuel system as well because the two work togeter. There needs to be a harmonious ratio of air to fuel mixture depending on the set up of your engine. If you upgrade air intake but not the fuel system, you may be running lean and actully see less performance. You can stop by or call an engine performance shop and tell them what your buying and see what adjustments they recomend for the fuel system. You may just end up needed to retune and that's all.
Old Jan 23, 2005 | 05:31 PM
1398spdr's Avatar
yea, i was thinkin of doin the fuel system anyway for future purposes, i guess ill just do all that together, take a day off and get it done......
Old Mar 15, 2005 | 07:07 PM
vertstanggt's Avatar
You don't have to do a fuel upgrade with a throttle body cause it's not a huge differance. It's simply less restrictive such as putting in a cold air intake or a cone filter. The computer will compensate for a certain amount of change in the air/fuel ratio. If you were intalling a new intake manifold or something like that you'd def want to upgrade the fuel system at least with a better pump. One the other hand if you've got plans and the money you may as well do it now and get it done. If you wanna go all out you can do rails, injectors, pump, and an adjustable fuel pressure regulator and you should be all set.
Old Mar 16, 2005 | 07:28 AM
1398spdr's Avatar
yea, i knew i wouldnt need it simply for the tb, i just figured while i was in there i should do it to get it out of the way......... but all is on hold till i get some cashflow again anyway...........[]
Old Mar 17, 2005 | 03:59 AM
It's all about how much you have to spend, lol. I wish I could just do anything I wanted to whenever I wanted to.
Old Mar 19, 2005 | 05:12 AM
1398spdr's Avatar
yea, thatd be nice huh..........
99clipsgst
Sep 7, 2005 02:32 PM
et2sub
Apr 22, 2005 09:37 PM
magno_313
Jan 16, 2005 04:15 PM
Davet2
Nov 18, 2004 01:17 PM
JimmyB
Jun 11, 2004 07:52 PM
