My Build/Progress Pics
Old May 4, 2009 | 09:27 PM
Default My Build/Progress Pics
This is my awd 1990 Eagle Talon Tsi that I picked up last summer for $1800 w/ 92k miles on it, got it from Va.
Pics of when I got it, pretty much stock w/ a rebuilt 6 bolt engine, manley valve springs, k&n, s16g turbo, act pp, and a wally 255 pump. It need a few things but nothing major, missing timing belt cover and oil leak.
Old May 4, 2009 | 09:31 PM
Abt a week of owning it, I fixed the oil leak (cracked oil pan and castle plug was loose). Installed hks 264/264 cams, replaced the fuel filter, new timing belt tensioner arm, and dejon tool intake.
Then a little later added a new K&n, 2g maf and evo 560cc's. Replaced the cracked v/c and v/c gasket. Also at this time I deleted all the emissions, a/c, cc and cleaned up the wiring and did a mini wire tuck.
Old May 4, 2009 | 09:32 PM
Installed fmic and short route piping.
Old May 4, 2009 | 09:34 PM
Cleaned up the interior and swaped out the seats.
My favorite mod, 2g shift ****.
Old May 4, 2009 | 09:36 PM
Then the worst happened, I parked behind my g/f when I came home for lunch and she did this.
Old May 4, 2009 | 09:38 PM
Then donor rad support from my parts car.
Old May 4, 2009 | 09:40 PM
All fixed up.
Old May 4, 2009 | 09:44 PM
Went to the track for the fisrt time. Running abt 17 psi and w/ a bad 60 ft.
1st run
60ft 2.225
330 5.835
1/8 8.719
mph 85.31
2nd run
60ft 2.222
330 5.846
1/8 8.734
mph 86.49
3rd run (wasn't even ready and by far the worst)
60ft 2.553 (yes I know)
330 6.091
1/8 8.940
mph 87.18
4th run
60ft 2.194
330 5.795
1/8 8.675
mph 86.48
Oh and my car weight 3020 w/o me in it.
Old May 12, 2009 | 06:03 PM
Installed my afpr and converted my wiring harness over to 91-94 years by swaping two pins at the ecu and installe a chip so the tach would operate properly.
Old May 12, 2009 | 06:11 PM
Abt a week ago my car would overheat after a 30 min drive and pushed coolant out of the over flow. Did a compression test and 1,2, and 4 were at 150 psi while number 3 was at 130 psi. Pulled the head and found that the waterjacket near #3 cylinder was the culprit.
Installed my evo 3 o2 housing.
Installed my jmf small battery kit. Got this one off Brent from jmf.
And started my wire tuck.
