o2 sensor code po 420
Old May 31, 2009 | 03:08 PM
roccu's Avatar
Default o2 sensor code po 420
I just put on a new high flow cat and a new muffler and since then every now and then the check engine light comes on, code po 420. I know it has something to do with air passing from the cat, could this just be because of the new cat? Should I just put a o2 simmaltor on or could this be something i should have looked at? I have a evo 8 at 90,000 miles.
Old May 31, 2009 | 03:52 PM
BrokeDad's Avatar
It's a very common occurrence with the mod you did. The upstream and downstream O2 sensors are monitored for a certain balance. You have "upset" the balance the system is used to looking for. Solution - I dunno .. I'm sure others will offer some up.
This URL might give you a better understanding of what is going on:
http://www.aa1car.com/library/p0420_dtc.htm
Old May 31, 2009 | 04:53 PM
yes get an 02 sim or perform the check engine o2 "fix" . for the 'fix' you will need to search around for the write up on how to do it. I did one on my Evo and it worked with not cat at all up untill I did a turbo upgrade. It cost about $5 and a small amount of free time. I think you can find more info on EvolutionM.net
Old Jun 1, 2009 | 08:20 AM
Old Jun 1, 2009 | 05:36 PM
that what I was talking about. I cant access the DIY section it shows up empty when I go in there so I couldnt link it
Old Jun 1, 2009 | 09:07 PM
Mike, you have to change the display settings at the bottom of the page from "last month" to "begining" since all sections are defaulted to only show the past month to reduce loading times and such.
You can also change this setting in the userCP to have it always show threads to a curtain date
UserCP >> Edit Options >> Thread Display Options >> Default Thread Age Cut Off
Old Jun 4, 2009 | 05:49 AM
roccu's Avatar
alright cool thanks guys i will give that a try
asim281
Mar 11, 2008 12:21 PM
Catch22!
Sep 3, 2007 07:08 AM
Darkspeed
Aug 29, 2006 09:41 AM
fwerp
Apr 13, 2006 11:58 PM
green_gs12
Aug 4, 2005 05:34 PM
