Where Can I Find An OBD1 Scanner For My 1992 Mitsubishi Mirage?
Old Jun 25, 2009 | 07:06 PM
Arch's Avatar
Default Where Can I Find An OBD1 Scanner For My 1992 Mitsubishi Mirage?
Do anyone know where I can get a OBD1 Scanner for my 1992 Mitsubishi Mirage. I have called a few auto parts places out here, just to be told that they don't carry and can't order any for my car. I've tried another autopart place, and I was told that they have an OBD1 & OBD2 combination for my car that would cost in the upper $200.00. I'm not looking to pay that much money on a OBD scanner. There are only two places out here, where I live that could check my car. I'm sure they will use a OBD1 & OBD2 combination scanner or they probably even have a OBD1 scanner that can scan my car, but they charge a lot, just to give me a code and I rather buy my on, just in case, I need it later on.
I really want to know why my check engine light is coming on.
Old Jun 26, 2009 | 09:07 AM
BEAT's Avatar
That's the cheapest price for the OBD 1 AND 2. Some cost thousands of dollars.
That is the right price.
Why do you need a OBD. if you are going to use it once? They might charge $26.00 to $70.00 to plug the OBD on your car and to get the codes and reset it.
Old Jun 26, 2009 | 01:54 PM
BrokeDad's Avatar
(deleted)
Old Jun 27, 2009 | 09:23 AM
Arch's Avatar
Thanks for the replies, Beat and Brokedad.
I wanted to get me an OBD1 scanner, so that I can see why my check engine light is coming on and just in case later on down the road, the light comes on again, after I have the first problem fix.
But, I don't have to buy an OBD1 scanner, I found out that I don't need a OBD scanner to gets the code from my car. That's good news.
Old Jun 28, 2009 | 08:14 PM
samabhi126's Avatar
What is the use of OBD1 scanner? Is it needed for every vehicle?
Old Jun 29, 2009 | 07:13 AM
Arch's Avatar
Samabhi126,
An OBD1 Scanner is used on cars 1995- below. Certain scanners go with certain cars. We would need an scanner made for import cars.
If your check engine lights comes on, the scanner would give you a code to help you know what's wrong with your car.
If your car is a 1996- up model, you can't use go to Autozone or even Advance autoparts and have it read for free.
geo jf
Jun 30, 2008 12:50 PM
Karter17
Jan 21, 2008 08:10 PM
Gstfat
Dec 27, 2007 10:29 PM
DR_NO
Feb 14, 2005 11:51 PM
