1992 3000gt vr4 Sputters on idle and dies T_T
Old Aug 6, 2009 | 02:34 PM
PoorVR4's Avatar
Default 1992 3000gt vr4 Sputters on idle and dies T_T
just fixed my car, turns out the problem was the ecu , it was just replaced with a new one. now there is a diffrent problem(this car seems to have a multitude of problems), Everything ran fine but the car was shut off and a couple hours later, restarted, but all it did was
Crank-->Start-->Ugly horrible idle-->No check engine light-->3 seconds later---->dies (there is a strong gas smell comming out the exaust pipe those 3 seconds it's on)
I've been researching to the point where I started having dreams about researching, this is what I've narrowed it down too.
-It could be the fuel pump(but a bad fuel pump means it wont start, right?)
-It could be the fuel pump is on but isnt recieving enough power from the fuel pump relay, while it's on(should I just buy and change the relay? If the fuel pump relay is bad wouldnt there be a check engine light or not?)
-It could be the ECI or ECU fuse in the front blown due to a huge sub and a heavy amp sucking speaker system was put in, after a day of that sub the car had this problem, can that cause a eci or ecu fuse to blow?)(how would I even check? Can I just look at it?)
We thought it was the ecu again but all 3 ecu's have the same problem, no caps are leaking on 2 of them , they are in perfect conditions, cant be MAF because there is no check engine light(but it does have the same symptoms)
sigh, has anyone seen anything similar?
Old Aug 6, 2009 | 11:27 PM
PoorVR4's Avatar
anyone?
Old Aug 20, 2009 | 08:00 PM
ms.denise43's Avatar
Cool I have similar problem...but I have a 1992 Mitsubishi Diamante...
I just took my car today to AAMCO for a FREE Diagnostic Test.
Results: Code 31 - Knock Sensor Circuit Problem & Code 14 - Throttle Position Sensor Adjustment
Don't know what this means exactly, but will be taking it in to be repaired in the morning.
ms.denise43
Old Aug 22, 2009 | 12:24 AM
doodfood's Avatar
Just wondering if you found out what the problem was, would be interested to know..
SmoothGentleman
May 4, 2008 07:04 PM
jamsk
May 2, 2008 01:22 AM
underpressure2003
Apr 29, 2008 12:04 AM
foleyit
Dec 7, 2004 12:45 AM
g35girl
May 12, 2004 12:43 AM
