MMCS Speaker test
Old Aug 8, 2009 | 01:25 PM
bleacherbum's Avatar
Default MMCS Speaker test
Those of you that have the MMCS/RF system-- If you hold SET + NAVI to get into the service menu, and do the speaker check, where you can test the Front Tweeters, Front and Rear Speakers, and SubWoofer independently--what kind of results do you get--or what do you hear?
Front Tweeters--High Frequency Tones only? Intermittent?
Front and Rear Speakers-- High and Low Frequency Tones? Alternating?-should there be only Low tones for the Front Door as the Front door speakers do not have integrated tweeters? Should the Rear speakers with integrated tweeters have both High and Low?
SubWoofer--Low Frequency Tones only? Intermittent?
Any input appreciated!
Old Aug 8, 2009 | 09:44 PM
rcpax's Avatar
I think it only tests that the speakers are working or not. So it's either with tone, or no tone. I remember it's all continuous tone, nothing intermittent.
Old Aug 10, 2009 | 11:49 AM
jangledang's Avatar
When I do the test I get intermittent for all the speakers
Old Aug 10, 2009 | 08:11 PM
For the front and rear doors, is it alternating High/Low ? do the Front and Rear sound the same?
Old Aug 11, 2009 | 07:18 PM
jangledang's Avatar
From the speaker test it appears that the rear doors do not have an integrated tweeter. For the front doors I get high and low intermittent while for the rear doors I only get low intermittent.
Old Aug 13, 2009 | 12:09 AM
Thanks--that's what mine do--and I thought it kind of odd---you would think the integrated tweeter speakers for the rear door would test with alt High/low--and the front lower door would be Low only with high only for the standalone tweeters at the front of the windows.
Was there a noticeable difference in volume? Did the back speaker tones seem much lower?
Old Aug 13, 2009 | 12:18 AM
After some searching. jangledang, i found this---posted by you:
" Default RE: 9 speakers or 7 ???
brian 360 is right. I was just as confused as you were when I could only see 7 speakers. If you do the speaker test in the calibration menu(I think this is navi+set), the rear speakers will play a mid-range tone with intermittent tweeter tones mixed in. "
So were they working at the time--is there something going on with the MMCS speaker test or the DSP/crossover circuitry in the amplifier? Or do the rear tweeters just fry really easy?
Old Aug 13, 2009 | 01:52 PM
jangledang's Avatar
I guess i misspoke in that previous post. There are only nine speakers in the mitsu so i dont think that there are burned out tweeters in the rear doors. For my car, the front doors sound a little lower than the rears, but it could just be relative to your position in the car.
EMonz57
Jun 4, 2008 09:55 PM
F.O.G.
Jan 21, 2008 07:49 PM
ryant25bb
Oct 12, 2006 12:54 PM
92montero007
Jun 2, 2004 03:21 AM
