FAST key battery life?
Old Aug 30, 2009 | 05:22 PM
rip14's Avatar
Default FAST key battery life?
What is your average life for your FAST key? Mine is about 3 months old, and I believe it is already about dead.
I have to hold it about an inch from the door to get it to work. My wife’s fast key still works from a distance. I use mine multiple times a day, as she only uses it once or twice a week.
I would still think that I should get more than 3 months with daily uses.
Old Aug 30, 2009 | 06:22 PM
Printerman's Avatar
Smile
My Fast Key has been working since Nov. 2007 and works great...I wiil replace the battery in a few months just to be safe......
Old Aug 30, 2009 | 07:11 PM
jsrd's Avatar
The mine are good after 2 years and 2 months. . .l
Old Aug 30, 2009 | 07:57 PM
tdford's Avatar
Have been using the same one since June 2007 with no problems. Probably battery failure, get a swapped out. And if you have already and problem still exists then have dealer replace fob.
Old Aug 31, 2009 | 01:29 AM
klas's Avatar
yup, has been using mine since the day I got it, 2 years exactly
btw, anyone knows what type of battery do we need (07 key)?
Old Aug 31, 2009 | 01:34 AM
outpack's Avatar
I think its a CR2032 battery. About the size of a nickel.
Old Aug 31, 2009 | 01:50 AM
jsrd's Avatar
Is true, CR2032, 3 voltios, for 07-up models. . .
Old Aug 31, 2009 | 06:36 AM
rip14's Avatar
Just one CR2032?
My wife works at an electronics store, and gets those things for about $0.50. So even if mine only lasted 3 months I am not going to complain.
Old Sep 1, 2009 | 09:11 PM
mitsupartsman.com's Avatar
what model year is your vehicle?
certain 2007 model fast keys will remain in test mode and drain the battery down
Old Sep 1, 2009 | 10:04 PM
smily157's Avatar
Yea, I just replaced mine in both of my remotes. I have had the car 2 years, and I have noticed a decrease in the range, with both fobs, even after changing the battery... so I don't know. But my second one I never use, it is just a backup and it drained at the same rate as the one I use everyday. I finally knew it was time to change it when the car told me the battery was low, although it only said it once and I drove like that for another 2 weeks.
mathai
Jul 19, 2011 01:22 AM
ShortyRider
Jan 19, 2011 10:48 PM
ProjectDrknss
Aug 9, 2007 01:39 AM
cerberus9
Jun 22, 2007 10:12 AM
Grahms_eH
Mar 26, 2007 04:25 PM
