A/C light flashing and blowing hot air
Old Aug 31, 2009 | 10:23 AM
trtmntdude's Avatar
Default A/C light flashing and blowing hot air
Have a 2002 GTS convertible and when i'm driving on the highway with the a/c on it is fine and blows cold. But when i get into city driving Stop/go after maybe 10 minutes the a/c light starts flashing and it blows hot air. Anyone else have this problem or have any idea what may be the problem?
I've had it checked at a a/c shop and they wanted to do $1300.00 in repairs replacing the compressor etc. but I know that it is something a lot simpler than that.
Old Sep 1, 2009 | 08:47 PM
trtmntdude's Avatar
No one???
Old Sep 1, 2009 | 09:51 PM
mitsupartsman.com's Avatar
the condenser is not cooling properly either because your fans aren't working or you've leaked coolant and your car is overheating. check your coolant level and radiator hoses wear they attach to the engine for leaks.
when your condenser does not cool itself properly the abnormal pressures turn the system off.
Old Sep 2, 2009 | 12:40 PM
trtmntdude's Avatar
Thanks mitsupartsman.com. Much appreciated
Old Sep 3, 2009 | 05:01 PM
Killswitch's Avatar
as a side note they didnt make GTS's in 02, so you either have a GT or the year is wrong
Old Sep 4, 2009 | 05:37 AM
trtmntdude's Avatar
It is a 02 GT Spyder. Thanks for pointing that out. Now that i have the badge right my a/c works just fine.
Old Jun 21, 2010 | 09:55 AM
godawgs2008's Avatar
Default air in 2002 eclipse
Mine has began to do the same thing in the last couple of months. Sometimes i can drive it everywhere and it will never happen and other times as soon as i turn the car on it doesnt work. im not leaking coolant, and my car isnt over heating. about how much will this cost to fix?
EclipseFLAGirl
Nov 9, 2008 11:10 AM
mattyblast
Aug 3, 2006 02:47 PM
Silvertooth
May 22, 2006 05:06 PM
