2003 montero has trouble code p0301
Old Sep 2, 2009 | 01:12 PM
psychoscoot's Avatar
Question 2003 montero has trouble code p0301
p0301=cylinder 1 misfire how do i fix this?
Old Sep 2, 2009 | 01:34 PM
jrmdir's Avatar
What's your mileage? If a six year old Montero has never had the spark plugs and wires replaced, that's likely your problem. Parts are reasonable but it's a relatively big labor project. See: http://www.monterosportonline.com/diy-perf2.html
It's not a foolproof check, but get your car in total darkness, let your eyes adjust and look around the wires to see if there is electrical arcing when the engine is reved up. No 1 spark plug is almost directly below the oil filler cap so you might check to see if there's a lot of oil on the wire and plug connector.
Ron
Old Sep 2, 2009 | 04:57 PM
redturboeclipse's Avatar
It's exactly as it says, misfire in cyl. 1.
As stated above, check spark plug and wires as the most obvious.
Too bad its a PITA to change em.
Old Sep 3, 2009 | 11:16 AM
thanks guys
Old Sep 9, 2009 | 05:50 AM
lovinmrv's Avatar
Default 2001 Monty Ltd plug removal instructuions?
Ron
Ron,
Is there a similar link for the Ltd? or is the procedure about the same?
Old Sep 9, 2009 | 12:24 PM
jrmdir's Avatar
Good question.
I'm only familiar with the 3.5l engine in my '99 full size - which is the same as the one in the instruction link. I suspect the major parts of the project are the same but can't guarantee.
Can someone here with a later model answer this question?
Ron
Old Sep 24, 2009 | 07:59 PM
mtc137's Avatar
I do know on the 3.8 you have to pull the intake manifold to get at the plugs. Yes, a big PITA for the shadetree machanic.
beetlenut
Jan 22, 2017 06:11 AM
CHIKE
Mar 10, 2014 09:34 PM
crash77
Dec 19, 2013 10:57 AM
p0301 help needed
Jul 21, 2010 01:32 PM
Mobiledj
Dec 4, 2008 07:04 AM
