Spark plug change
Old Sep 16, 2009 | 10:08 AM
Obakemono's Avatar
Default Spark plug change
Hey all,
Anyone change their sparkplugs on a Montero Sport with the 24V-single cam engine? (2000,3.0l)
It looks like I might have to pull the top half of the intake to get to them. If I have to dig that far into the engine I might as well change the timing belt (I just bought it used).
Rob
Old Sep 16, 2009 | 11:00 AM
jrmdir's Avatar
Lots of people have changed plugs. Do a search - it's a common topic. Here's a helpful website: http://www.monterosportonline.com/diy-perf2.html
It sounds odd, but there really isn't much overlap between this job and the Timing Belt. So not much labor saved doing them together. But it will consolodate your downtime I guess.
Are you sure you need a TB? How many miles on the current one? Mitsu admits they're good for at least 100K miles even they say to replace at 60K. (The fine print in the owners manual says that if you live in CA and a couple of other states the belt change interval is 100K - even though it's the same belt.) If you do change it, do the water pump as well.
While you're in this mode, check for oil seeping from the rear cam seals at the rear of the heads. They are a common problem but it's easy and cheap to replace the O-rings.
Ron
Ron
Old Sep 16, 2009 | 01:50 PM
Obakemono's Avatar
Default Plugs
The monty has 110k on it and runs very well. I need to change all the belts (cracked and dried out) so when I do that I will pull a timing belt cover and inspect the belt. I'll go from there on what to do once I see the condition of the belt. There are no records for the vehicle and the PO only had it for about a year, so I will start from what I know and build a good base (tune up, fluid changes ect) because I plan to keep it for a while.
I did have an oil leak, but just snugging up a bolt on the valve cover cured it. I'll check the o-rings once I do the heavy work on it.
Rob
#1 Stunna
Jun 7, 2007 05:59 PM
spyder4g63t
Oct 30, 2006 09:07 PM
jefem24
Jul 21, 2005 09:31 PM
jsnichols1
Feb 10, 2005 01:40 AM
AngelViper33
Aug 12, 2004 02:47 AM
