91 gsx turbo stock psi??
Old Oct 1, 2009 | 12:25 PM
new91gsx's Avatar
Default 91 gsx turbo stock psi??
alright i just bought my first dsm and its bone stock whats the stock psi?
and how high can it be turned with stock fuel system? i know i will need a boost controller is there anything else besides that? please let me know thanks. i already did a fullllllll tune up on the car!
Old Oct 1, 2009 | 12:42 PM
you also need a boost gauge to tell you what you are running. But the most i would run on the stock car is 15psi.
Stock boost is around 10-12psi. It can vary sometimes depending on health of car, location, ect
Old Oct 1, 2009 | 12:44 PM
new91gsx's Avatar
well what should be the first thing i do to the car performance wise besides turn up the boost to 15 ?
Old Oct 1, 2009 | 04:56 PM
Plugs, wires, air filter, fuel filter, coolant flush, oil change, timing belt service, change the trans fluid, change the transfercase fluid, change the rear diff fluid, clean out the intercooler, compression test, and boost leak test.
Once you do all that crap above, then you can start doing all the free mods.
If you want to be cheap and mod it first before the maint stuff you WILL break something.
Old Oct 1, 2009 | 05:23 PM
new91gsx's Avatar
i did all of thous things!!!! what are the free mods and i also herd to put the 2g intake on it ????
Old Oct 1, 2009 | 06:01 PM
I replied to your pm but do a search on free mods b/c they're are many different things you can do.
Also www.vfaq.com is your best friend.
I Drive Naked
Jan 26, 2008 05:08 PM
zeanimal2001
1st Generation
Aug 31, 2007 11:23 AM
2slow
Jun 19, 2007 11:14 PM
maximus6770
Nov 15, 2006 09:13 PM
feardafish
Feb 4, 2006 09:49 AM
