HELP, white smoke
Old Oct 3, 2009 | 01:31 AM
flat4's Avatar
Default HELP, white smoke
Hi guys, i drive a lancer with a 4g15 engine. lately my engine is producing white smoke and is coming out from the exuast, it's like a fog machine.
Help, need your advice?
thanks
Old Oct 3, 2009 | 09:21 AM
does it do it all the time. Does the car overheat. And check to see if you have lost any coolant. Also do you have a check engine light?
Old Oct 4, 2009 | 09:15 AM
flat4's Avatar
Hi, it happens when you put load on the engine. It does not over heat. Coolant level ok. Check engine is not on when engine is running.
thanks
Old Oct 5, 2009 | 11:24 AM
mtc137's Avatar
Default Head gasket
Sounds like you got a bown head gasket
Old Oct 6, 2009 | 05:38 AM
flat4's Avatar
Thanks, would you know torque value of cylinder head?
Old Oct 6, 2009 | 08:27 AM
he just said that he has none of the symptoms of a blown headgasket
Old Oct 6, 2009 | 12:14 PM
I'd try a hydrocarbon test and check for a possible headgasket, there really isnt anything else that would cause a cloud of white smoke.
Old Oct 6, 2009 | 02:16 PM
^^running very rich will. could have something wrong with the emissions. In that case i would have expected a check engine light though. So who knows.
Old Oct 6, 2009 | 04:19 PM
Running rich will be black or grey depending how rich the mixture is. White is usually coolant/moisture.
Old Oct 6, 2009 | 04:28 PM
Leakdown/compression test should show the truth.
I'm betting the head gasket is gone.
