Mitsubishi
Old 10-03-2009, 06:58 PM
nesport nesport is offline
Default 03 Montero Ltd Front intermittant grinding noise
Anyone ever come across an intermittent grinding noise in the front passenger area? It started doing it upon braking (but the brakes are fairly new), but has since started doing it even when driving and accelerating. My gut is telling me it's a wheel bearing, which I'm being quoted about $1000 to replace both bearings and hubs. The dealer isn't quite sure as they can't get it to duplicate the noise (shocker there huh?). Can anyone think of something else it could be? It has about 87,000 miles on it. Thanks.
Old 10-04-2009, 12:32 AM
jgbrules jgbrules is offline
i have done several of these. 1 a few weeks ago. customer complained of bad grinding noise at times when comming to a stop at high speeds or at very low speeds. 1st one was a b*#!@ to diagnose but it was it was the solenoid pack that controls 4wd engagement. loses vacume when comming to a stop and the 4wd slightly engages and thus the grind you hear. that solenoid pack is located on the passengers side wheel well area in the engine compartment. not very expensive. around 50 bucks. not hard to change either. just watch your vacume lines and dont mix them up. good luck!!
Old 10-06-2009, 10:08 PM
How do you test to see if that's what it is? Is there any chance that it could be the wheel beerings/hubs? The mechanic says he visited some sites and found a tech tip that said that the hubs have a defect in them and to replace if this occurs. He's always been good with me over the years with multiple cars, so I don't think he's trying to screw me, but at the same time he doesn't do a lot of work around Montero's so he may just not know. If there's a test like running it in 4wd and it not doing it, I'm in for that test. Thanks.
Old 10-06-2009, 11:02 PM
challenger4x4 challenger4x4 is offline
Maybe it's the same thing that's happening in this thread...
http://www.mitsubishiforum.com/forum...ad.php?t=34006
__________________
- 2003 Montero Sport XLS AWD (current)
- 2006 Nissan Altima SE-R (current)
- 1999 4X4 Montero Sport Limited (retired)
- 1997 4x4 Montero Sport XLS (retired)
- 2003 Galant LS (retired)
- Lots of cars and SUVs before that
Old 10-28-2009, 12:21 AM
so it was the 4wd solenoid, actually two of them. Way cheaper than the hubs/bearings. Thanks.
Old 10-28-2009, 02:49 AM
redturboeclipse redturboeclipse is offline
Wow big thanks for jgbrules on that diagnosis.
Old 10-30-2009, 05:24 AM
Skiddy Skiddy is offline
It could also be the free wheel switch, located on the front differential. That is even cheaper than the solenoid pack, but a bit of a pain to replace.
__________________
'00 Mitsubishi Pajero: 3.0L 12-valve (290,000+ km/181,125+ miles, Original Owner)
'09 Mitsubishi Galant GTS Premium: 3.8L, Fully Loaded
Tags
2002, accelerating, bearings, differential, engagment, front, grinding, lancer, left, limited, makes, montero, noise, solenoids, sport, wheel
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
