2001 eclipse gt wont stay running!
Old Oct 4, 2009 | 11:11 AM
mitsuV6's Avatar
Default 2001 eclipse gt wont stay running!
This is really bothering me since i need to use my car for work. I have an auto and when im in park it stays on but as soon as i put it in drive reverse or even neutral it goes below 1000 rpm and barely stays on i have to put it in neutral at red lights and stop signs and rev my engine like im taunting the people next to me pretending i have standerd we all know hoiw bad rollies are in autos lol... possibly my alternator? someone help im going to drive it into a wall, this is one of many issues.
Old Oct 4, 2009 | 02:34 PM
Do you have a check engine light?
Old Oct 4, 2009 | 07:58 PM
sounds like an air leak or an idle sensor issue
Old Oct 6, 2009 | 05:23 PM
mitsuV6's Avatar
Yeah. That's on and my flex pipe is rotted out. Big exhaust leak. Getting it welded tomorrow.
Old Oct 6, 2009 | 05:51 PM
Get the car scanned and post the dtc #.
Old Oct 7, 2009 | 07:09 PM
mitsuV6's Avatar
do you have a check engine light?
171 134
Old Oct 7, 2009 | 07:25 PM
P0171 is bank 1 lean so you probably have a vacuum leak which would explain the stalling.
p0134 an oxygen sensor code (bank one sensor one) This is probabaly on b/c of the p0171.
Old Oct 8, 2009 | 09:21 AM
mitsuV6's Avatar
Sometimes can a vacume leak mean something as small as needing a new gas cap?
Old Oct 8, 2009 | 09:49 AM
sometimes but in this case i doubt that is the problem. I gas cap can give a check engine light, but it wont cause stalling issues. Something like this i would say either a bad gasket on the intake, a bad sensor in the idle or emission system, or a worn vacuum lines
Old Oct 8, 2009 | 07:12 PM
A gas cap wont fix your issues. Like TE said either an intake manifold gasket is leaking or a tired o2 sensor.
