shaking inbetween 45 MPH and 65 MPH???
Old Oct 12, 2009 | 11:19 AM
tfeesl's Avatar
Post shaking inbetween 45 MPH and 65 MPH???
When I reach 45 MPH my car starts to shake and when I reach 65 MPH it stops?
what could it be?
  • Ball Joint?
  • Tie Rod?
  • Wheel bearings?
  • Bad Balancings?
Old Oct 12, 2009 | 12:38 PM
Try balancing the tires.
Old Oct 14, 2009 | 12:36 AM
tfeesl's Avatar
so i brought it into a shop
and found out my tie rods were bad, so i changed them...
shaking is ALMOST gone!
doesnt shake as much but still shakes between 50 and 60 MPH...
ball joints were good....
balancing? or alignment?
Old Oct 14, 2009 | 02:49 AM
Check balance and alignment.
Old Oct 14, 2009 | 06:33 PM
worn tie rods shouldnt cause a shaking.
only something in an out of round or out of balance situation can.
Old Oct 14, 2009 | 09:43 PM
tfeesl's Avatar
well explain why when i changed the tie rods 99% of the shaking went away?
Old Oct 14, 2009 | 11:24 PM
it allows you to diminish the shaking slightly. but the tie rods will not create vibration.
Old Oct 19, 2009 | 06:33 PM
BEAT's Avatar
it will. it is part of the steering column. I have the same problem. ball joint, tie rod,tires,rims/mag, disc brakes worn out (warp) etc etc will cause your steering wheel to shake or vibrate.
if you don't fix it can Kill.
Old Oct 19, 2009 | 07:44 PM
Old Oct 20, 2009 | 06:30 PM
no. it wont. it will cause slop in the steering. it can cause noise, handling issues, prematurely worn tires, etc.etc.
but to vibrate, something needs to create the vibration. a tie rod which does not rotate will not. ball joints cant.
you can get motion, but the constant vibration can not be manufactured at a ball socket.
