driver side window rattles
Old Oct 24, 2009 | 10:16 PM
lilaznviper's Avatar
Default driver side window rattles
when i have the window down just a bit like a very small crack open as i drive the window rattles but when the window goes like a quarter down the rattling stops
anyone else have this problem??
Old Oct 25, 2009 | 03:03 PM
pilcan's Avatar
I have that one too and I just ignore it.
Old Oct 26, 2009 | 08:48 AM
mtryan0505's Avatar
I have it as well, I ussually wind the window down then roll it up just a cm and it stops. I've just been too lazy to fix it.
Old Oct 26, 2009 | 11:51 AM
good i thought i was the only one
the rattle is annoying and my car only has about 400km on it. i guess i'll tell them about it when i get my first free oil change at mitsubishi when i hit 6000km
i have yet to drive the car in the cold as where i live the temp has not yet diped that far down
Old Jan 17, 2010 | 10:14 PM
so update
i went to the dealer and got the problem fix. they said they found something between the window and the guides and they just removed it and added some lube. now the rattling is gone!
Old Jan 30, 2010 | 11:24 AM
suffrn6's Avatar
the rattling problem is caused by the 10 mm nuts coming loose on the window arms. remove door pad, put window down so you can access the nuts, remove nuts put thread lock on them and reinstall. problem solved. HTH Chris
GAMitsuBoy
Dec 17, 2017 08:25 AM
Outlander-RY
Sep 1, 2015 09:31 AM
XeoNoX
Aug 27, 2012 10:18 AM
pcc183
Jun 3, 2012 09:31 AM
bishigt_18
Nov 1, 2008 07:24 PM
