04 Endeavor Limited sub replacement - 4 or 8 ohm?
Old Oct 30, 2009 | 07:51 AM
04 Endeavor's Avatar
Default 04 Endeavor Limited sub replacement - 4 or 8 ohm?
The factory Infinity sub in my wife's 04 Endeavor Limited finally bit the dust, and I want to replace it with an aftermarket sub. I have removed the factory speaker, and found several options that will fit in the factory mounting hole, but can anyone tell me if the factory sub is 4 ohm or 8 ohm? Also, any ideas which connector on the factory speaker is + and which is - ? They are not listed on the connector or the speaker itself
Thanks for the help!
David
Old Nov 2, 2009 | 01:22 PM
btunell's Avatar
Default Speaker
I would suggest that it is a 4 ohm speaker, since the others are rated for that. As far as which connector is +/-, it really doesn't matter, unless you are concerned about phase interference with the other speakers, but I doubt you'd really notice it. The speaker doesn't care, it will operate just fine if you have them switched.
Old Nov 2, 2009 | 02:28 PM
thanks for the response...my initial thought was 4 ohm as well, but it is always better to double check.
As far as the +/- issue, I'll hook up the new sub both ways to see if the audio quality is any different
thanks again!
idremhd
Aug 24, 2015 09:51 PM
bytemywhat
Sep 23, 2012 10:16 AM
the tin man
Aug 9, 2012 05:17 PM
the tin man
Jun 6, 2012 08:17 PM
04 Endeavor
Feb 2, 2011 10:49 PM
