tune?
Old Nov 16, 2009 | 03:33 PM
Jarreddl's Avatar
Default tune?
so i bought this car from a friend and im almost positive that there is nothing mechanically wrong with it. all it needs is a tune since it has bigger cams and injectors in it and so on. how do i go about doin this or getting this done? i know about dsmlink but if i do it myself im scared to mess something up.
thanks
list of everything in it:
DNP Tubular Manifold
Bullseye T04B 60 Turbo
2nd Gen Maf Setup
Turbo Back Exhaust
Front Mount Intercooler
Greddy Type S Blowoff Valve
Walboro 255 Fuel Pump
Injector Clinic 750 cc (injector)
Aeromotive Fuel Pressure Regulator
Innovative Motorsprots Wideband w/Gauge
Apexi AFC NEO
90 Big Rods
ACL Pistons
ARP Head Studs
Balance Shaft Removed
New Showdown Motorsports Head
New Brian Crower 272 Cams
New Head Gasket
New timing belt
Fluidamper Harmonic Balancer
New water pump
Fresh plugs and wires
Old Nov 16, 2009 | 05:02 PM
I know dsmlink is very user friendly, I use other stuff to tune w/ b/c I'm poor.
Old Nov 16, 2009 | 05:38 PM
Jarreddl's Avatar
so you dont think i bought a dsm link and tuned it myself i wouldnt really mess anything up? im not planning on tuning it to max performance or anything.
Old Nov 16, 2009 | 05:41 PM
You'll be fine. You could always get an eprom ecu send it out and have it chipped to your mods.
Old Nov 16, 2009 | 06:04 PM
Jarreddl's Avatar
how would i go about doin that? what exactly would i have to do for that anyways?
Old Nov 16, 2009 | 06:10 PM
Old Nov 16, 2009 | 06:54 PM
Jarreddl's Avatar
ughh idk what all that means....like the 1G ECMLink v3 Package with ECU
1G DSM or the 1G ECMLink v3 Package with Non-EPROM Conversion
1G DSM. which one would i need?
Old Nov 16, 2009 | 07:01 PM
Do you have an eprom ecu?
Old Nov 16, 2009 | 07:06 PM
Jarreddl's Avatar
idk im pretty sure its stock. i dont know what eprom is...
Old Nov 16, 2009 | 07:14 PM
Some 1g ecu's came w/ eprom chips from the factory. The only way to find out is to remove the ecu and pop the cover off and look for the chip.
