Ground ignition connecter ?
Old Nov 20, 2009 | 01:15 PM
pepper's Avatar
Default Ground ignition connecter ?
hey guys, another dumb question, I think. I want to set the timming after haveing the dist. out of a 93 eclipse 1.8 . The book i have says 2 put a ground jumper from ignition test connecter to a good ground, this plug on my car has 2 **** inside that thing. Do I ground both **** or one of them ? Thanks fore any help Sam
Old Nov 20, 2009 | 03:43 PM
It should only have one wire and that goes to ground.
Old Nov 22, 2009 | 03:38 PM
pepper's Avatar
Thanks dsm1990gsx, I went back and looked closer at that timming wire & it does have 2 **** in it.on closer inspection I notice the 2 **** are made of rubber or are little covers on them, the only single wire is black & goes 2 a condencer 2 ground. Am I looking in the wrong place ? over by the battery.
Old Nov 22, 2009 | 03:59 PM
It should be over by the battery, but theres gonna be two similar connector one for ign timing adjustment and the other is a fuel pump test connector. The one you want has a yellow wire w/ a red tracer.
Old Nov 23, 2009 | 02:36 PM
pepper's Avatar
Thumbs up
Thanks again dsm I will get out tomorrow and set the timeing, I'll check back in and let u know how it turns out.
Old Nov 27, 2009 | 01:09 PM
pepper's Avatar
dsm1990, I found that wire and all went well, thanks 2 you much you saved me alot of time and also you taught me a thing or 2 that i will always be able to use in the future , so thanks again. sam
Old Nov 27, 2009 | 08:18 PM
No problem.
Old Dec 4, 2009 | 11:59 AM
pepper's Avatar
No problem.
dsm1990gsx----I had that car running like a new one the wife blue the heater hose ran the dang thing and blue a new headgasket its apart again which one shoud i keep her or the car LOL,,,LOL Sam.
Old Dec 4, 2009 | 01:27 PM
That sucks, well at least the head gaskets are easy to replace on the 1.8.
Old Dec 6, 2009 | 08:40 AM
pepper's Avatar
very true, but dang it sure is cold outside, but i bet there wont be any bad hoses on it after this. I suppose it was supper good luck that the head was not warped or cracked because it got all 4 clinders on the gasket, strange, it had 2 be relly hot but i started it up and it ran fine , so i put water in it and it blowed it back out but it never did miss a lick. now she wants me to change it over 2 auto trany. can this be done with this bisy? like we use 2 do the old cars back in the day?
