2000 GT motor mount replace??
Old Feb 23, 2010 | 05:42 PM
66ca's Avatar
Default 2000 GT motor mount replace??
i just bought my son a 2000 Eclipse Gt and im trying to figure out which motor mounts are bad....probably all of them. the motor moves back and forth more than it should i think when you go from reverse to drive. Is there a best way to swap them out and a best place to get the parts from. I know that at Autozone, just the one on the passenger side is like 180. Are all of them that expensive? How bad does it hurt to drive the car with it like this? Thank you for any help....i need it
Old Feb 25, 2010 | 03:25 PM
66ca's Avatar
wow, nobody huh? Guess i will just figure it out.
Old Feb 25, 2010 | 03:34 PM
The motor mounts in these cars are fairly soft to begin with. You should be able to see visibly if they are sagging or torn.
Old Feb 25, 2010 | 08:52 PM
Killswitch's Avatar
you can buy prothane inserts off of ebay or several other websites, they are much harder and ive heard when idling its slightly rougher because they are harder and dont have the give of the stock ones, they do last longer though, much cheaper also
Old Feb 27, 2010 | 02:54 PM
66ca's Avatar
took it to a shop and they said all 3 motor mounts and the trans mount were bad.
Will this set of mounts work?...
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Feb 27, 2010 | 04:44 PM
Killswitch's Avatar
it should work, im not really sure if it comes with just the mount or the inserts also, the inserts are probably what is bad on yours eventhough the actual mounts to break occasionally
Ryan
Jul 28, 2007 09:02 PM
Gstfat
Jun 11, 2007 10:10 PM
shiznit013
Oct 11, 2005 12:45 AM
EclipseGSRoadRacer
Oct 17, 2004 03:36 PM
1spyder2nv
Aug 12, 2004 09:54 PM
