front mount vs. side mount
Old Jun 11, 2007 | 06:18 PM
Gstfat's Avatar
Default front mount vs. side mount
I raced astock gs-t with a front mount and i have the stock side mount,and i beat it easily by a car and a half,should i keep the stock intercooler,and only upgrade it to a front mount when i upgrade the turbo?
Old Jun 11, 2007 | 06:20 PM
Dusty Eclipse's Avatar
Default RE: front mount vs. side mount
Something odd is up there... I think his car may have had other problems...
Old Jun 11, 2007 | 06:26 PM
Gstfat's Avatar
he had no chance,look at my signature im not completely stock,he was and he had bigger rims probaly 18's or 19's
Old Jun 11, 2007 | 06:33 PM
None of those mods are serious HP increases... But if he was stock with extra weight... I see what you mean. You have a T25 Id imagine?
Old Jun 11, 2007 | 06:38 PM
silvercoupe97's Avatar
If the car you raced was stock (minus FMIC), then that guy is an idiot for even putting that IC on. There's enough of a pressure loss with stock piping and IC...to add larger piping and a larger IC makes that stock turbo push even harder....blah, think of blowing a spitball out of a straw, then think of trying to blow that same spitball out of a hose sized straw. How red would your face get blowing out of that hosed size straw.
GstFat, your only advantage in your list is your intake. Your fuel upgrades are minimal and is limited by the stock injectors and stock fpr. You're only one step off the stock lines. The guy you raced was one step back from the stock lines.
I'm not trying to offend you GstFat, I'm trying to help you see the setup both of your cars have in terms of advantage/disadvantage.
Old Jun 11, 2007 | 06:45 PM
So , yes, like I originaly had said, its more than likely the other guy had a problem... do you know him? Why put a FMIC on an even otherwise stock T25?
Old Jun 11, 2007 | 07:23 PM
DSMTalonAWD51's Avatar
dont upgrade the ic until you have a big turbo, and try to look for a short pipe ic kit (hint, dont go with greddy)
looking at your mod list I see you took a non typical path.
id suggest getting these before anything else: (assuming you dont have them yet)
-upper ic pipe
-boost controller
-exhaust (catback, downpipe, high flowcat)
Old Jun 11, 2007 | 07:36 PM
ORIGINAL: DSMTalonAWD51
-upper ic pipe
-boost controller
I agree. I went with the short route for the same reason you're thinking.
GstFat, that path that DSMTalonAWD51 stated is the typical path because it's in line for future mods and is in somewhat of a chronological order.
I realize that you may have gotten your car modded that way already, but the suggested path is better than piecing things together here and there.
Old Jun 11, 2007 | 10:10 PM
sk8dudety's Avatar
was his gst an automatic too? that could also affect him being slower than you
centerline
4th Generation
16
Nov 10, 2015 01:09 PM
bishigt_18
Nov 1, 2008 07:24 PM
eclipsegst97
13
Jun 23, 2005 05:43 PM
baker_sk8er37
Apr 28, 2005 06:10 PM
Angel_408
Feb 17, 2005 05:18 AM
