6G72 Motor for 1993 Montero SOHC
Old Mar 24, 2010 | 02:13 AM
cyborg_89's Avatar
Default 6G72 Motor for 1993 Montero SOHC
I need to replace my motor and found a shop that has a used 6G72 3.0L SOHC long block from Japan that's from a sedan (I think it's from a Diamante).
The block looks the same, but I'm concerned about compatibility in regards to compression ratio's. I know I have to swap out all the brackets for the alternator, AC compressor, power steering and timing belt cover, intake manifold, and maybe fuel injectors.
I'm having a hard time finding a used Montero motor from japan and this is my best option with my budget.
Are there any issues with swapping the motor from a Diamante into a Montero?
Old Mar 24, 2010 | 09:10 AM
Montezuma's Avatar
I think one of the reasons you have a hard time finding a Montero/Pajero motor from Japan is because in Japan they were powered by a 4 cyl turbo diesel motor. Pajero's mostly had the turbo diesel.
Old Mar 24, 2010 | 01:45 PM
Skiddy's Avatar
Is this the 12-valve or 24-valve 6G72?
Old Mar 24, 2010 | 03:54 PM
cyborg_89's Avatar
It's the 12V motor.
Shadowplane676
18
Nov 19, 2022 10:28 AM
Shadowplane676
Jul 7, 2021 07:50 PM
csam
Jan 21, 2015 07:54 PM
duster6g72
Oct 17, 2012 11:08 AM
haribole
Mar 5, 2010 07:34 PM
