eclipse gst high idle after rebuild
Old Jun 10, 2010 | 02:38 AM
caseclipsegst's Avatar
Default eclipse gst high idle after rebuild
just rebuilt the motor, and its idling around 2000-2200 rpms...and when i put it into gear to take off it tries to take off fast, everything is hooked up as should be, all vacuum lines are hooked up.. any ideas?
what is the reg idle suppose to be??
Old Jun 10, 2010 | 08:22 AM
idle should be around 900-1000. try adjusting the BISS screw seen here
http://members.shaw.ca/dsm.1000q/Eng...er/2G/biss.htm
Old Jun 10, 2010 | 09:30 PM
i did tried that already, even shut all the way it still idles around 2000 rpms..
Old Jun 11, 2010 | 10:26 AM
tpl6's Avatar
Default idle speed controller
Is it throwing a check engine light? if so, it might be the idel speed control motor...
easy to fix but the part is like $300
shownuff80
Dec 9, 2014 12:02 PM
Denniskb
Jun 1, 2014 09:01 PM
LUKESGARAGE
Nov 16, 2013 03:34 PM
caseclipsegst
Aug 18, 2009 08:54 AM
yamahablaster8230
Aug 29, 2006 09:28 AM
