2000 Eclipse GT 6cyl
Old Jun 12, 2010 | 02:55 PM
nostrashawnus's Avatar
Default 2000 Eclipse GT 6cyl
I have a question. After running fine for years, last night my eclipse decided to not start.
Here are the symptoms:
1. Cranks just fine
2. The windows will not roll down
3. the radio works fine
4. The sunroof will not open
5. The fan will not turn on
As I am a Chevy guy, and this is my daughters car I need some assistance! I checked continuity on the relays in the under-hood fusebox. I looked at all the fuses and they seem fine. I do not hear the fuel pump prime when I turn the key to start, but I have read conflicting info on whether or not it should make noise. I have seen many posts about the Fuel Pump Relay, but I have not even found where it is to check it. (once again several posts with conflicting information) So if someone will send a pic that would help me greatly! Any other information or things I can check? I really do not want to take this to the dealer as I am sure it is a ECM or relay that is causing this issue.
Thank you all for your help!!
Old Jun 16, 2010 | 10:06 PM
MitsMaster's Avatar
Im thinking Ign switch. mounted on the end of the ign lock cylinder. 6 wire connector.
sweezy18
May 24, 2016 06:43 AM
JFENDERSON91
Oct 10, 2012 11:24 AM
tatnu72
Oct 26, 2011 05:19 AM
kashmiriomar
Feb 8, 2011 11:21 AM
