Oil Leak From Sensor on Block????
Old Jul 8, 2010 | 09:41 AM
pghtech's Avatar
Default Oil Leak From Sensor on Block????
I have a 1996 Eclipse with a 420A,
I recently purchased this car and replaced the head gasket along with all the other top end gaskets, timing belt, and water pump. I got it for real cheap since the head gasket blew. Everything seems to run fine.
I noticed I was leaking Oil, when I checked it out its not coming from the head gasket as I feared, but it seems to be coming from a sensor on the engine block. When I crawled under the car there are two sensors on the block, the one that is leaking is closer to the transmission on the drivers side and a real pain to get at. Is this a known issue / problem with these cars.. what is that an oil pressure sensor?
I have to assume it was leaking before and I just didn't notice since I really just made sure it started prior to digging into the head gasket and didn't want to run it long with water in the oil.
Any ideas or comments?
Old Jul 22, 2010 | 10:31 PM
Phil424's Avatar
Well, I do know my CPS is leaking oil. Honestly, don't worry about it. Its normal and doesn't hurt anything. As long as the sensor doesn't get oil on it and u get a check engine light, its not a big deal. If you want, the only way to fix that is to replace the sensor.
Old Aug 18, 2010 | 10:41 PM
squishyamocito2007's Avatar
check the o-ring on the sensor maybe it doesnt have a good seal
Old Aug 19, 2010 | 07:59 AM
pghtech's Avatar
Update, The Leak was actually coming through the Oil Sending Unit, $15 part and $10 special socket, replaced it and no more leak. I couldn't not worry about it since it was dripping on my exhaust and smoking like crazy and making a mess where ever I parked my car.
paquillo9688
Mar 24, 2012 08:34 AM
ccernst
Jan 14, 2011 08:38 AM
TheRock0720
Nov 12, 2010 12:30 PM
dorian7
Jan 22, 2008 06:09 PM
ttenn
Jun 10, 2006 01:45 AM
