P0400 EGR Flow Malfunction..HELP!
Old Jul 23, 2010 | 10:31 PM
maylene's Avatar
Default P0400 EGR Flow Malfunction..HELP!
I need to do my smog check but my check engine light is on and the code reads P0400 EGR Flow Malfunction..any suggestions on how I can fix this without spending hundreds of dollars..my car is a 2000 mitsubishi mirage..Thanks!!!
Old Jan 10, 2013 | 10:08 AM
Abdiel Santamaria Tejeira's Avatar
Hi Maylene
I got this issue with my car, what did you do to solve this problem?
regards,
Old Jul 12, 2019 | 10:07 PM
James Rahn's Avatar
2000 Mitsubishi Galant
keeps throwing p0400 code
has a intermittent rough idle under load
tested vacuum at throttle body 0 at vacuum line with yellow tracer stamped A on the throttle body port
get about 17 at The hose with green tracer stamped E on the throttle body port
cannot clear the port the hose with yellow tracer going to egr solenoid...
can I just tee off the e port to supply vacuum to the egr solenoid untill I can pull throttle body and clear the port?
Any suggestions would be greatly appreciated
PMR
Oct 8, 2015 08:29 PM
jmansour
Dec 12, 2013 01:35 PM
lrt
Aug 24, 2009 02:12 PM
mdoc111
May 16, 2007 05:06 PM
gant
Apr 3, 2007 11:29 PM
