how to keep my fog lights on
Old Mar 20, 2003 | 03:17 AM
wookie's Avatar
Default how to keep my fog lights on
<FONT color=black size=2>I have a 1992 eclipse and the fog lights won't stay on.They only stay on if you hold the on button inn.</FONT></P>
Old Jun 25, 2003 | 02:59 AM
Mitsu92GS's Avatar
Incredible! I have exactly the same problem with the '92 GS. It may be a problem with the button, maybe it doesnt hold...but it could be a short circuit or something...heck i dont know bout electronics.
Old Jul 2, 2003 | 01:11 AM
WHiTE GSX's Avatar
you could buy a new button, or wire the fog lights to a toggle switch that you can turn on and off when you want... take the button apart and see it a clip is broken... could be as simple as that...
Old Jul 8, 2003 | 02:28 AM
Puppet0's Avatar
my girlfreinds car has the same problem, i think a relay inside the button is fried but havent checked it out yet, take it apart and look for any burnt components
Old Jul 10, 2003 | 08:13 PM
w8ing's Avatar
I took one apart and did not notice any burnt components. What I did notice was a hook that appears is supposed to latch onto something within the plastic but does not. Otherwise, I do not know what the metal hook is for except to tear up the plastic from within. Can anyone tell me if you push the switch if it supposed to only release part way or fully just as if I were turning it off? I really do not think it matters, but I have put 2 switches on my car now from a junk yard and they both do not work. I have turned serveral more off and on but they seem to release the full amount either way and I am not sure if that is normal.
Old Aug 1, 2003 | 01:45 AM
eclipse2gnt03's Avatar
the spring snapped that holds it in and clicks in caise it happened on my old integra
Old Aug 11, 2003 | 01:09 AM
sanitarium16's Avatar
its the fog light button. The button has a little plastic piece inside of it that holds the button down. Over time it snaps and you need a new switch. It takes 5 minutes to install. I bought a new fog light switch from mitsubishi for around 50 bucks.
Old Aug 7, 2005 | 06:56 PM
ftykustomz's Avatar
Default RE: how to keep my fog lights on
wire up new switch check out power and ground but sounds like switch if that dont work put new power source example hook switch from battery to lights
Old Aug 8, 2005 | 02:29 AM
DSMTalonAWD51's Avatar
ORIGINAL: ftykustomz
just to let you know this was posted 2 years ago....
roundigo
Nov 11, 2016 12:12 PM
btlagunas
Mar 6, 2010 05:22 PM
vpleonard
Apr 27, 2004 08:47 PM
quicken
Mar 6, 2004 11:37 AM
2fast4u
Sep 6, 2003 06:44 PM
