Eliminating Engine Light
Old May 17, 2005 | 04:22 AM
hodunwun's Avatar
Default Eliminating Engine Light
91 Mitz Eclipse GS. I have repaired a code for a bad air temp sensor (I think). Engine warning light still comes on after a few minutes of driving. Question is: do I have to reset/clear the memory at the diagnostic connector or just disconnect the battery? If this is done at the connector, can it be done with an OBDI meter? Can it be done manually at the connector. Thanks for your attention.
Doug [8D]
Old May 17, 2005 | 09:35 AM
Sanguinius's Avatar
Default RE: Eliminating Engine Light
You should be able to clear the code with the reader at the connector. If you DO clear it and it comes back then obviously the problem isn't fixed.
Old May 17, 2005 | 01:28 PM
DSMTalonAWD51's Avatar
any time u reset a code and the problem wasnt really fixed, the light will come back on the 2nd time you start the car.
Old May 17, 2005 | 05:53 PM
patsevo8's Avatar
What code number were you reading?
Old May 18, 2005 | 12:37 AM
Sanguinius's Avatar
Yep problem definately isn't fixed you need to find out exactly what the code # is and ask here or look up the causes for that code.
guyjg
Nov 13, 2021 03:27 PM
shum_87
Aug 29, 2009 05:05 AM
pgb205
Jun 4, 2009 10:40 PM
EclipseFLAGirl
Nov 9, 2008 11:10 AM
serenabkhan
Nov 23, 2007 05:44 PM
