2000 eclipse driver side tail light..
Old May 25, 2005 | 03:42 AM
eclipse7rdshop's Avatar
Default 2000 eclipse driver side tail light..
im having a prob. with the driver side tail light driver side rear corner light an license plate light. When i switch the lights on those 3 lights dont go on...the signal an the brake like works on on that tail light...im not sure whats wrong i checked the bulb changed it, checked the fuse an checked the relay nothing was wrong wit any them...Anyone have any ideas wut might be wrong...Let me know. Thanks.
-Anthony
Old May 25, 2005 | 09:58 AM
get435's Avatar
Default RE: 2000 eclipse driver side tail light..
pull the light out maby teh plug is loose. check for bare spots on the wire when u pull it out it could be shorting out.
Old May 25, 2005 | 10:41 PM
Sanguinius's Avatar
I'd say check the plug. The light socket may be corroded or possibly the contacts spread out enoughthat the bulb doesn't contact anymore
Old May 27, 2005 | 02:31 AM
Yea i cheked all that wires are no corrosion at all...i dont really get whats wrong does make sence to me..
Old May 28, 2005 | 02:36 AM
Sanguinius's Avatar
I'd get a voltmeter and turn thje lights on and see if there is power to the bulbs. That will give you a start if there is no power then check for a ground and check for breaks in the wire.
Old Jun 1, 2005 | 01:42 AM
Thanks guys i figured it out.
Old Jun 1, 2005 | 10:56 PM
Sanguinius's Avatar
Cool wut was the problem? for future reference.
newoutlanderfan
Aug 29, 2011 09:29 AM
bishigt_18
Nov 1, 2008 07:24 PM
StatixNWH
Sep 30, 2006 06:22 AM
StatixNWH
Sep 11, 2006 03:44 AM
KameleonKlipse
Jun 9, 2006 01:19 AM
