Making an engine swap in a Mirage?
Old Jan 8, 2004 | 01:49 AM
Mirage2000's Avatar
Default Making an engine swap in a Mirage?
<FONT face="Arial, Helvetica, sans-serif" color=black size=2>Hey, my friend has told me that i can replace my 4G15 with a JDM Eclipse GSTengine...is this possible?</FONT></P>
Old Jan 8, 2004 | 02:25 AM
Hybrid4g64's Avatar
Yep...just put a USDM 4g63 in it....basicly the same thing as JDM 4g63....notmuch different between the 2 motors other than the intake mani....correct me if im wrong
Old Jan 12, 2004 | 07:12 PM
AfterHrsPlayer's Avatar
The intake manifold of the cyclone is a little but wider the the domestic 4g63. Other than that, they are the same. You will also need a JDM ECU to work with the cyclone engine.
Old Jan 12, 2004 | 07:47 PM
Mitsu-Tech's Avatar
well it can be done ....but be ready for a trans and axles that little 2.0 motor is far from a turbo eclipse i would'nt do it but i'm a dealership tech and we stay away from swaps like that .</P>
every time you turn around you find something wrong, if your a seasoned mechanic you'll do just fine but if it's all new to you just get the eclipse</P>
my 2 cents</P>
Rick</P>
Old Dec 22, 2011 | 03:52 AM
Evobound29's Avatar
Default Making a engine swap in a mirage??
Hi I'm trying to do a engine swap on my mirage I have the 1.8 l in now and I want the 4g63 engine with the AWD trans. I was told evo 4 5 and 6 were the best to go with. My issue at the moment is trying to locate the rear drivetrain off a evo 5. This way I can have the mirage AWD instead of FWD
Let me know your input on any warnings or snags i may run into and any good advise you can give me for this job. Thank you
Davidevolv
Dec 21, 2011 06:47 AM
Dj_Renegade
Oct 23, 2009 10:55 AM
RCJr9186
Oct 8, 2005 01:42 AM
1rippinGT
Jun 4, 2004 04:28 PM
mekka
Oct 17, 2003 07:51 PM
