90 GSX Won't start
Old Aug 18, 2005 | 12:35 AM
TheAntiCivic's Avatar
Default 90 GSX Won't start
Ok, here's the story.
Driving along on the highway. Whenever I shift gears the car cuts out, let out the clutch, it starts back up. So I get off the highway, stop at a red light, and it cuts off. Now it'll crank and try to start but it won't start, so I've gotta push it into a parkin lot and wait for a tow truck.
I get it home and I'm lookin at just about everything. I've got the Pocket Logger system and nothing really looks out of the ordinary. I can't really find a culprit. New plugs, wires, fuel filter, coil, ignition module. It's just not starting. Fuel pump is good (pocket logger gets it to turn on), I put a used (working FPR).
I just can't figure out whats keeping it from starting... ANY ideas?
Old Aug 18, 2005 | 11:16 PM
Default RE: 90 GSX Won't start
Well, I got it started today.
It won't idle on it's own, I gotta keep it at 1500rpm to keep it from completly stalling out. It has a really rough time idling at 1500 tho. Sputters and doesn't accelerate at all.
Smokes a little bit but not a huge ammount. So now I gotta figure out what's makin it run so rough.
Old Aug 19, 2005 | 10:31 AM
get435's Avatar
if you said i was smoking do a compression test.
Old Aug 27, 2005 | 01:58 AM
owensj's Avatar
Crank Angle Sensor...?
Old Aug 29, 2005 | 10:13 AM
get435's Avatar
if all that is wrong try the cmap or crank pos sensor my car did the same thing until i got a cam pos sensor.
Old Oct 12, 2005 | 11:09 PM
eclipse93gs's Avatar
if it makes alout of clicking noises and stuff and begins to smoke more and more then its probably your engine..right before my engine completely blew up it was idleing at 300rpms and if i didnt hold the gas down it was stalling out. my best friend is a mechanic and he told me it was because one of my cylinders was shot. anyway hopefully thats not the case its an expensive fix to get a new motor. good luck
Old Oct 12, 2005 | 11:11 PM
Sanguinius's Avatar
Sounds like a crank or cam pos sensor to me so far.
mysticrythms
Mar 19, 2014 08:17 PM
eclipsen
Aug 28, 2005 11:43 PM
truck2121
Aug 17, 2004 11:15 AM
workmanls
Jul 23, 2004 04:58 PM
cbjacer
Jun 26, 2004 04:45 AM
