overdrive not kicking in
Old Jan 23, 2004 | 12:22 AM
scitron's Avatar
Default overdrive not kicking in
Hello,</P>
I have a 1995 galant that the overdrive is not kicking in. When I go over 60 MPH, the tach shows 3,000 RPM. At 70+, its shows 3,500 RPM. The car runs great and the tranny is shifting at lower speeds but not at higher speeds. Only have 72K on the car. Any help would be appreciated.</P>
Thank you</P>
Sam</P>
Old Jan 23, 2004 | 09:27 PM
nasgue's Avatar
i have a '96 Galant that currently has the same problem
Old Jan 24, 2004 | 05:58 PM
scitron's Avatar
Hello,</P>
Just wondering, have you had a chance to get the tranny checked out by anyone to see what may be causing this problem?</P>
Thanks,</P>
Sam</P>
</P>
Old May 25, 2004 | 09:54 AM
tweeter11's Avatar
Default RE: overdrive not kicking in
I have a 98 galant es with a similar problem. I find that if I give her hell up to 80 then slowly let her come down to 68 mph overdrive will kick in and I will be setting on 3K rpm. Now sometimes if I accelerate at a slow rate it will shift into overdrive around 50 mph.
Old May 27, 2004 | 03:39 PM
LeapingGnome's Avatar
If it's only showing 3,500 at 70mph, how do you know it's not kicking in? On my 94, the overdrive quit working and at 70mph I am just under 4,500rpm.
OCdreamin30
Jul 22, 2010 06:28 PM
diskretephx
Feb 2, 2007 10:15 AM
Zaemz
Oct 8, 2006 09:27 PM
blt2rck
Jun 12, 2004 11:41 AM
glenn
May 13, 2004 04:46 PM
