Iridium Spark Plugs
Old Aug 19, 2005 | 03:06 PM
Sephiroth's Avatar
Default Iridium Spark Plugs
Hi, i want to know if the iridium ngk spark plugs go well for a 00 eclipse, and what set of wires is recommended. Thanks
Old Aug 19, 2005 | 03:16 PM
g9s5t's Avatar
Default RE: Iridium Spark Plugs
i would personally go with denso... i have those in my 95 gst and they have worked great so far
Old Aug 19, 2005 | 04:07 PM
wicked_outlander's Avatar
denso iridium is good to go, for wires...go MAGNECORE WIRES ( 8.5mm)
Old Aug 19, 2005 | 04:44 PM
Patrick's Avatar
Administrator
i have NGKs in my 3.0l....i had bosch, and they were awful.
Old Aug 19, 2005 | 05:13 PM
DSMTalonAWD51's Avatar
bosch 4's are terrible, iridiums are not good in a turbo car but theyd probably be fine for you. Id still go with ngks though.
Old Aug 19, 2005 | 05:23 PM
Patrick's Avatar
Administrator
with the bosch's i developed an awful miss..so i went through the hassle of replacing them for the NGKs..and it went away...
Old Aug 19, 2005 | 06:05 PM
g9s5t's Avatar
dsm why are iridiums not good in a turbo car?
Old Aug 20, 2005 | 03:43 AM
DixonsGst's Avatar
yea i have the denso iridium plugs in my 97 gst and ever since i put them in i have bad miss's in high rpms. What is the cause of this? When i replaced the plugs i also did the wires with msd superconductors.
Old Aug 20, 2005 | 04:56 AM
ORIGINAL: g9s5t
a lot of dsms just experience idle/misfire problems with them. you can try em if you want, but for how expensive they are it may not be worth it. just about everyone uses NGKs because they work great and are oem. use BPR7ES plugs if you are stock or mildly modded, use BPR6ES if you have a bigger turbo and are running high boost.
Devilzxxx
Oct 7, 2010 02:52 AM
eclipsefanatic
Feb 13, 2007 02:39 AM
ictponder
Mar 5, 2006 05:41 AM
MrJayDeeOne
Jan 6, 2006 06:29 PM
JimmyB
Nov 30, 2005 07:03 PM
