Addinga Power wire through a firewall.
Old Jan 23, 2006 | 07:36 PM
jimbo_limited's Avatar
Default Addinga Power wire through a firewall.
I have a 96 Eclipse Rs and i cannot find a way to install the power wire for the amp.
Can anyone tell me where i can add the wire through the firewall?
thanks
Old Jan 23, 2006 | 10:59 PM
Ryan's Avatar
Default RE: Addinga Power wire through a firewall.
Hey I had the same problem running my positive wire in my 2000 Eclipse GT. I ran an 1/0 gauge positive through the firewall by simply drilling a hole and then siliconeing it. That's about the only advise I can give you. Hope it helps you.
Old Mar 15, 2006 | 06:16 PM
jeffery0266's Avatar
I have a 95 rs and I ran the power wire to the passenger side,there is a bunch of wires there and I just pushed it through and had someone grab it and pull it on through.It wasn't that hard to do.
Old Mar 15, 2006 | 09:21 PM
ictponder's Avatar
ORIGINAL: Ryan
If you look behind the carpet on the drivers side, you will see a wire harness going through the side leading to the fusebox in the engine compartment. It take a bit more finess than drilling a hole in metal, but the end product is much more to be desired. You can also use a spare slot in the fuse box for a fuse for your amp.
Outland70
May 15, 2011 03:14 PM
Riotralph
Mar 26, 2011 05:22 AM
sssnake
Nov 23, 2010 02:28 AM
lillben07
Jun 2, 2008 09:18 PM
snoowboardin58
Jul 9, 2006 02:44 AM
