2004 Lancer Coil not firing
Old 08-27-2015, 10:51 PM
Seaborn5's Avatar
Default 2004 Lancer Coil not firing
What makes the coil pack fire is it crank senor or the cam senor?
both where replaced and car did would not start. I pulled engine code and it says that the new camshaft senor is bad. I replaced with the old cam sensor. The car now starts but it is only running on two cylinders. The coil pack is new, and as the car runs it gets very hot. I have an ignition tester and the other coil is firing.
Old 10-26-2015, 01:08 AM
up-and-down's Avatar
Hmmm replace or borrow a working set of coil packs to know if which one is the faulty. Also make sure to reset the ecu to erase very codes.
davidsdlck
12-22-2020 06:51 PM
b--ryan
05-31-2009 07:51 PM
macrader1
06-20-2008 11:25 PM
tex1994
03-05-2008 03:22 AM
horine
04-13-2004 02:49 PM
Quick Reply: 2004 Lancer Coil not firing
