*HELP* 1990 Misubishi 2.0L *LOOK*
Old Jul 17, 2010 | 02:44 PM
Winter_C's Avatar
Default *HELP* 1990 Misubishi 2.0L *LOOK*
Hello, I am currently in the process of putting the timing belt back on my car, and I have made it thus far but am stuck right here:
Align the crankshaft and oil pump sprocket timing marks (Figure 9). Since the oil pump sprocket also drives the second, lower balance shaft, be sure to verify the position of the balance shaft. This can be accomplished by removing a threaded plug on the side of the cylinder block and inserting a .310 shank Philips screwdriver into the hole (Figure 10). If the screwdriver can be inserted at least 2.400, the timing of the balance shaft is correct. Otherwise rotate the oil pump drive sprocket one revolution and retest. The screwdriver should remain in the block until the timing belt installation is complete.
Where is the threaded plug? Does anyone have a picture or detailed explanation? Because I can not find it.
Thanks!
Old Jul 17, 2010 | 03:23 PM
dsm1990gsx's Avatar
Here you go
Old Jul 17, 2010 | 03:41 PM
Winter_C's Avatar
Just to clarify, what side of the motor is that on?
Old Jul 17, 2010 | 04:38 PM
Winter_C's Avatar
Nvm got it, thanks man!
bloms433
Nov 22, 2010 07:00 PM
BudP
Mar 15, 2010 08:58 PM
tmd_63
Feb 11, 2008 04:35 AM
jvilleman04
Mar 21, 2006 09:57 AM
