1992 Eclipse 4G63 N/T - engine jumps
Old Mar 31, 2015 | 11:34 AM
Colt16v's Avatar
Default 1992 Eclipse 4G63 N/T - engine jumps
Sorry for the title, english is not my native language, so its kinda difficult to explain.
I just bought an Eclipse, 2.0 16V non-turbo, and it runs very well, except when i lift the throttle, the engine "jumps", like it misfires or something, even though it shouldn´t be possible when decelerating. It does the same when on a straight road, and the road bends down a bit. If i keep the throttle in the same spot, and the car begins to push the engine, it becomes worse. Its kinda like when there is moisture in the ignition leads. But the engine pulls very well all the way to 7000rpm, and no problem taking off either.
Any ideas? Also if it doesn´t make sense, please let me know and ill try to explain
Thanks!
Edit: When running idle, it usually hangs around 1000-1500rpm, and it sounds like it misfires from the exhaust.
Old Mar 31, 2015 | 01:20 PM
Akzle's Avatar
a tune up.
compression check, new spark plugs and leads, ignition timing, fuel delivery calibration.
loudmtx05
Nov 6, 2017 07:53 PM
daddy24boys
Mar 20, 2017 03:29 PM
gabe
Oct 19, 2013 05:24 PM
hattrick9712
1st Generation
Mar 23, 2011 04:04 PM
betterdayz19
Oct 24, 2004 11:59 PM
