1g help please
ORIGINAL: patsevo8
dude, 1g get walking crank. why would you think that they don't? did you know that toyato supras, mr2 and a few nissans also get walking cranks? probably not. i've been doing imports long before i could drive.
but anyways, back to the situation. have you been able to get the car started?
ORIGINAL: Sebba
6 bolts dont get crankwalk
But anyway. Just as a simple solution (because sometimes thats all it is) and this is just a hunch because i got this problem and couldnt figure out what it was. Check your battery connection and see if you have some bad corrosion or a bad terminal. Because i had the problem and it sounds like you have a power issue because when you turn your PS is taking some power and you said thats when it stalled. This might not even be the problem but its something to check
Thanks for all the help. I will check the corrosion on the battery cables. Sorry to say this, but in the chiltons book, it only shows the crankshaft in the 95-newer models. The cam/crank position sensor are the same thing. I am also going to change the fuel pump tonight. Any advice on doing this? I am going to buy new spark plug wires also and install my junkyard TPS. Hope to hear some more comments.
ORIGINAL: patsevo8
I know his car is a 7 bolt, and I know that every 7 bolt has the possiblity of walking the crank. But crank walk is cause mostly by heavy abuse on the bottom end. I know this is a race car but the non turbo 4g63 has different cams and lacks a turbo that its brother 7 bolt does, so his motor dosent see nearly as much compression as the 4g63t. The chances of that motor walking are 1 in a million... litterlay. Further more, not all 7 bolts walk, many stock 7 bolts have been dynoed making some where in the nebighorhood of 400hp with out any walking issues. In light of that I cant see this non turbo 4g63 making some 160hp(?) walking... unless it been deprived of oil
![Big Grin](https://mitsubishiforum.com/forum/images/smilies/biggrin.gif)
When it stalls, check for injector pulse while cranking. If there's none, you likely have a bad computer. The Capacitors tend to leak electrolyte all over the PC board causing erratic behavior. Super common in the 1G
Joel, CA
Joel, CA
Hear is the update. Changed the fuel pump, spark plugs, plug wires (ACCEL 8MM), and O2 sensor. took it racing on saturday night. At first it would not stay running, stall after running for 5 min. So, we advanced the crankshaft sensor. It stayed running, but when I went into the corners, it would cut out like it was sloshing fuel away from the pump because when I got on the straightaways it was mad fast. Any ideas?
i was also told it was my baffel in the fuel tank. That it was busted and moving the fuel away from the pump. Just got done checking the fuel cell and baffel is not busted.
Please need ideas or input as soon as possible.
