7 bolt to 6 bolt swap
Hey guys, i just purchased a 6 bolt 4g63t to swap with my 7 bolt n/t, i was wondering if these would be straight swaps or if the motor mounts or eclectronics are any diffrent besides the ecu.
THanx alot, Zach
THanx alot, Zach
RE: 7 bolt to 6 bolt swap
sebbaa 93 non turbo IS a 4g63
the 420a didnt start till 95
it will fit right in, but your gonna have to deal with the resistor box for injectors or aftermaket ones, i belive you can make it run with the NT ECU, i know they will run but not sure that it does so well. you might have to end up going the easy route and putting in a turbo car wire harness and ECU just to get it overwith.
ive never done a 1g turbo swap YET so i cant tell you much about it other than its not as bad as people make it out to be, its just getting the right stuff to make it all work.
