7 bolt to 6 bolt swap
Old Aug 27, 2007 | 05:05 PM
zeanimal2001's Avatar
Default 7 bolt to 6 bolt swap
Hey guys, i just purchased a 6 bolt 4g63t to swap with my 7 bolt n/t, i was wondering if these would be straight swaps or if the motor mounts or eclectronics are any diffrent besides the ecu.
THanx alot, Zach
Old Aug 27, 2007 | 05:22 PM
Default RE: 7 bolt to 6 bolt swap
What car do you own.......... more specifically... GS/RS?
Old Aug 27, 2007 | 06:57 PM
Its a 93 GS n/t
Old Aug 27, 2007 | 08:18 PM
nick_200321's Avatar
if i am understanding you correctly, your putting a n/t in a car that already has turbo or via versa??
Old Aug 27, 2007 | 08:21 PM
grr nvm i re read it, ill shut up now lol
Old Aug 27, 2007 | 10:25 PM
You cant put a 4g63 in it.
Dude this is repeted like once a day
Old Aug 28, 2007 | 01:51 AM
racerx55's Avatar
sebbaa 93 non turbo IS a 4g63
the 420a didnt start till 95
it will fit right in, but your gonna have to deal with the resistor box for injectors or aftermaket ones, i belive you can make it run with the NT ECU, i know they will run but not sure that it does so well. you might have to end up going the easy route and putting in a turbo car wire harness and ECU just to get it overwith.
ive never done a 1g turbo swap YET so i cant tell you much about it other than its not as bad as people make it out to be, its just getting the right stuff to make it all work.
Old Aug 28, 2007 | 07:30 AM
Ergh.... im retardeddddd i thought this was a 2g
Old Aug 28, 2007 | 01:36 PM
racerx55's Avatar
lol
Old Aug 29, 2007 | 08:53 AM
jason clipse's Avatar
for a sec i thot it was a 2g too but yea if ur gonna swap the motor then get the ecu and harness too it makes it sooooooooo much easier cause then its just plug and play
