90 eclipse won't crank
Old Apr 26, 2007 | 11:36 PM
darksider's Avatar
Default 90 eclipse won't crank
Like the subject line say's, I have a 90 eclipse, I went to lunch today, came out half hour later and turn the key, nothing, car won't even crank, all I hear is a ticking sound coming from under the console, the lights, radio, everything else seems to work. I checked the battery, and it's good, car has had no startingproblems otherwise. Could this be the starter? or something else? any help would be much appreciated!
Old Apr 27, 2007 | 12:18 AM
Default RE: 90 eclipse won't crank
Starter. You said you hear a click so the solenoid is engaging.. its the starter.
My advice is, turn it to the on position and release it really fast basically making it click really really fast. After about 5 seconds of doing that really fast it should crank. If not then start carrying a hammer with you. When ever the starter gets stuck, give it a little knock on the case (if you can reach it)
Old Apr 27, 2007 | 12:25 AM
agallardo's Avatar
ORIGINAL: Sebba
YEP!!!!
Old Apr 27, 2007 | 12:30 AM
darksider's Avatar
Well, I pulled the side off of the console, and there is what looks like a relay maybe? that's what is making the clicking noise, I can't hear anything coming from under the car, I'll try the hammer trick tomorrow and hopefully it's enough to get the car home.
Old Apr 27, 2007 | 12:33 AM
Ok cool. Pretty sure thats it.
Let us know
Old Apr 27, 2007 | 06:03 AM
silvercoupe97's Avatar
Did you try and get it jump started at all?
A battery that isn't holding a good charge gives the same symptoms....turn the key and all you hear are relays clicking, all the while the radio and lights still work.
Old Apr 27, 2007 | 09:20 AM
i agree with silver. Im willing to bet its just the battery.
Old Apr 27, 2007 | 07:01 PM
93eclipsegsx's Avatar
but he said he checked the battery and it was ok.
Old Apr 28, 2007 | 11:21 AM
darksider's Avatar
Well folks, I'm happy to report I figured out my problem. I was positive it was the starter, so I began pulling stuff out of the way to get to it, seems there is a small 14 gage wire that come out of the loom and attaches to a clip on the starter with a simple 1/4" connecter. The end of that connecter had corroded apart, I simply replaced the connector put it back together and it sarted right up! all because of a little 10 cent part!
I want to thank you guys for all the helpful tips and suggestions!
spetznazer
Nov 18, 2013 01:06 AM
casterman
Apr 14, 2009 12:47 AM
clipse99
Jul 13, 2007 07:00 AM
WIECLIPSEGUY
Apr 11, 2006 10:56 AM
whitestallion10
Jan 6, 2005 01:20 AM
