96 Galant won't crank
Old Apr 11, 2009 | 10:38 PM
casterman's Avatar
Default 96 Galant won't crank
bought a 1996 Galant ES with 4 cylinder, automatic and 92000 miles from the insurance pool. It had a light hit in the right front headlight / fender and bent the lower control arm. I did not get any keys and had my locksmith cut one. When I turn the ignition to the crank position - nothing happens. I think it might be something to do with a security system. My thought is to put it on jack stands and hook up a remote starter button and see it that will let it crank. Any one know some magic pixie dust for me to try?
Old Apr 12, 2009 | 11:27 AM
Blck3G's Avatar
Firstly did you ever start the car? if not its probably because you didnt use Mitsubishi's Key.call up a local delear ask what key(code) brailed on the key you need.
Old Apr 12, 2009 | 05:10 PM
dsm1990gsx's Avatar
I doubt 96 came w/ a chip in the key? Check the battery condition and try using a prybar and hammer and tapping on the starter and see if it starts.
Old Apr 12, 2009 | 07:32 PM
casterman's Avatar
Default won't crank
I know the battery is bad, but I have a good jump box and when it is hooked up everything powers up -- just no crank -- good point about the starter condition. I will hook a "hot" straight to the solenoid and see if it makes anything happen
Old Apr 14, 2009 | 12:47 AM
Blck3G's Avatar
its a voltage thing. Or so ive heard, old teacher for AC worked at mitsubishi and said there are two different keycodes...and they send different voltages to the PCM or some ****. not 100 percent accurate been years since I took a A/C class.
spetznazer
Nov 18, 2013 01:06 AM
yaofeng
Dec 31, 2008 05:27 PM
clipse99
Jul 13, 2007 07:00 AM
darksider
1st Generation
Apr 28, 2007 11:21 AM
fred170
Jan 14, 2007 11:28 AM
